Error code :(
  • Error code :(
    just fitted a 3" turbo back scorpion and its goin in2 limp mode when it gets 2 4000rpm error code 124358! Any1 else had this problem?
    Astra edition-307, Cruise Control, Team Heko Wind Deflectors, 3" Scorpion non-res, Whiteline RARB, Courts CDTI conversion, EDS IPF Stage 2 software, VXRacing boost hoses - 288bhp
    P1243 turbocharger bypass solenoid valve voltage too large C-033
    P1243 turbocharger bypass solenoid valve voltage too small C-033
    P1243 turbocharger bypass solenoid valve open circuit C-033
    P1243 turbocharger bypass valve not in the target area C-033
    www.thevenuelondon.com / www.myspace.com/fatboyateallthepies
    the owner of the first zaffy detailed by vxrmarc and also the owner of the first bus sm'd by vxrcourt3
      vac pipe will have come off mate, is there a turkey noise (chattering) when you lift off while on boost? really common on astras when you tune them/fit exhaust etc. Check the small box down the back of the engine to which 2 vac pipes are attached, its best accessed from underneath, dab of superglue round the edge of the plastic connector. I'm 97% sure one will have come off. only other option is a split recirc valve, but thats unlikely. never known it to cause limp mode tho, that could be another issue.
        That's exactly what's happened mate! Hopefully if I put it back on and disconnect the battery the light will stay off! Cheers 4 that!
          mine did the same mate
