3 gadge conversion (GLASGOW)
  • 3 gadge conversion (GLASGOW)
    alrite guys just looking to get a 3 gadge conversion im located in glasgow just wondering if theres anyone thats able to help ?
    H20GYY
    hello h2ogyy, you might get a better response if you ask here your region mate
    http://www.vxronline.co.uk/forum/for...-Scotland-West
    also this might help a little , as you need to take your facial off, couldn't find a ''how to'' on the 3 gauge conversion,
    http://www.vxronline.co.uk/forum/sho...ering-controls
    i have water/oil temp /boost ,
    water temp>>>>> a little advice, take the bumber off and slame panel to help take the water pipe off to cut, + when fitting the sender use thread lock/seal , as it will leak, did for me, as i even trued tightening it up, which lead to snaping the sender, which lead to no car till i got a whole new sender sent out, as had already cut the water pipe to fit.
    oil temp>>>>>>, same as above use thread lock/seal on the sender in the sandwich plate, if you go that route, advice sell's a different way of connecting the senders, which is far better for reading's, not sure about how/where they are fitted, give him a PM he is a canny helpful lad
    it really is easy to do if you know how to do it lol, as i wouldn't of even tried it, till i seen it getting done,
    boost gauge>>> is a simple t-piece connection for the boost gauge easy to fit. just make sure you pe to your gauge, making sure this is enough befor you cut it,
    hth same way or other mate.
      i can do you a trim no probs....
        jiggers the man...done mine and many friends of mine.....cant go wrong
          yip, jigger is your man
            H20GYY
            Lol gadge
