Insignia washer jet Q
  • Insignia washer jet Q
    Right, this does seem stupid me making a thread on this but I have tried to get my original washers out but I can't! I have taped them up and given them abuse with a hammer, tried to lever them out, everything! Can anyone offer any advice on getting the standard washer jets out?
    VXRED
    Dap-r & wheels so far, plenty more to come!
    just put a bit of rag over the top of them and tap them out with a hammer
    they may be a bit stiff
    corsa arctic edition #257
    now sold
    REAR STRUT BAR FOR SALE!
      +1
      pull the seal back, lift the plastic up and then tap them as they might not have any space to knock back
      try it, if not get a sledge hammer lol
        Already tried that but taped them up instead of a rag! Will try again tomo, any other suggestions??
        VXRED
          3 shreaded wheat?
            step one, get down the gym and work on your guns
            step two, get a nice big hammer, as i did!
            step three, those little jets have just slept with your mrs! give them hell!
            job done, open a beer and relax
            Fitted them to my signum too, took me 3 mins on that car. soooooo easy, the astra is a pain
              as said just clout them with a hammer. taking them out is the easy bit lol, ur gunna have fun putting them back in
              NAAAAT
              Arden VXR, 19" Anthrecite alloys, TMS Stage 3, Forge FMIC, Remus, K&N Panel filter, Insignia washer jets, RARB, DAP's, Sight and light, Keyless, Forge recirc valve, Percys oil restrictor and breather box, 3 Gauge conversion, VXR front grille badge, VXRonline window stickers and The Origional Percys Airbox
                pulling them off the rubber hose is the bit i found trickiest . . . .
                  Hot water
                    Originally posted by TrystanG View Post
                    Hot water
                    . . . . . . . . never thought of that . . . . . .
                      Take the scuttle panel out, will make life much easier, will just take a little longer.
                        be carefull with the hammer, may end up needing a new scuttle/wiper panel.
                        use some hot water as said.. and push them from the top downwards towards the floor..
                          Yeah don't "proper welly" it, give it a sharp fast strike with the hammer. You could always try hot water as suggested, or even a bit of lube :P
                            mate for all the hassle it is not worth changing it.
                            i changed them on my Vectra and it is better (a little) but if i couldnt get them out or had to risk damaging something then i wouldnt bother.
                              Just take the whole scuttle panel off, rubber seal and 2 bolts for the wipers, whole panel pops right off. Soooo much easier than fiddling in a small space !!
                              James
