Lots of exhaust smoke on start up. Any ideas? :(
  • Lots of exhaust smoke on start up. Any ideas? :(
    As above, the problems got worse over the past week and a bit. . Started it this morning and it was like a cloud behind my car. Am I right in thinking it could be the valve stem seals leaking and the oil burning off on start up ? + if it is this will it be doing any damage to the car or will I just be losing oil?
    Also how much am I looking at to have this repaired?
    In the Barnsley area too so any good garages you can recommend id appreciate it as vxl are a rip off and im yet to find a good one round here. Cars stage 2 as well so just guessing my warranty wont be covering this
    Could be valve stem seals or potentially the turbo seals. Nope with being modified you won't be covered by warranty.
    How much oil are you burning? Do you notice any smoke under engine load i.e. giving it a bit of throttle?
    | Find | Watch | Follow |
      No smoke under full throttle once warmed up. Just if the car has been stood overnight for example which is what made me think of the valve stem seals. Any idea what sort of money I'm looking at to have this repaired? or how easy it would be to do myself?
        Blue or white smoke
        Clique #14
          Originally posted by Rabbid View Post
          Blue or white smoke
          Not really sure on that one bud :/ the colour it is on start up on a really cold day if that helps
            sure its not just condensation??
              Its just condensation i would'nt worry about it, perfectly normal unless the car is'nt running right.
              Used to have a Silver Lightning Vectra VXR 280, Currently in a Seat Leon FR TDI
                Ive had the car over a year and its only started doing this over the past week and a half though? 59 plate with 20k miles
                  cant see it being condensation either theres loads of it
                    off to halfrauds to get some additive to replenish seals see how that goes . .
                      Find someone who actually know what they are doing to do this as they could go again if not done correctly.
                      If it isnt this, like Gareth states it wll be Turbo seals due to not having an Oil Restrictor Banjo fitted with a large bore exhaust
                      Here you go - read this (solution ) !
                      http://www.vxronline.co.uk/forum/showthread.php?125079
                        Thanks for the help bud, appreciated
