Oil Restrictor Bolt buying advise
  • Oil Restrictor Bolt buying advise
    Hey guys,
    As iv bought a breather box for my astra vxr I was thinking of replacing the above as not in warrenty and want to look after turbo etc.
    Just want a bit of advise which one of these you would get?
    Are these both the same?
    http://cgi.ebay.co.uk/Astra-VXR-GSI-...item3f0a81c7ac
    http://www.lmfvauxhall.co.uk/Astra-a...ctor-Bolt.html
    I cant seem to find Courtneys one for another comparrison...
    Am i safe to go with the cheaper one from fleebay?
    Cheers in advance guys
    people only really advise this when upgrading to a bigger bore exhaust. no need if standard.
    Some people have said and so have courtenay, you dont need one of these if you have the correct oil. think he said w30 which is thin and think thats the reason for courts not supplying them.
    The one on ebay doesn't look like it comes with the washers. I bought mine for £12 second hand but not used, think regal sell them for £25
    BLACK VXR CS stage 3, 3" Scorpion, Forge FMIC, Ksports, Quaife LSD, Revos, 3 Gauge, Dynabeams, Forge recirc & actuator, DAP-Rs, RARB, Team Heko's, Percy Cdti, cool running thermostat, Blue SMD's and white LED number plate bulbs.
    **Progress thread here!**
      Yes go with the cheaper one. Basicly the same.
        I have only got a standard exhaust and am running Mobil 0W - 40 Fully Synth? I thought the consept of it was to look after the turbos whatever the exhaust??
          I've also only got the standard exhaust on mine, and I run 5W40 oil. Have had the restrictor bolt fitted for over 18 months now.
            I have used the one from LMF my self on a few cars for people
            all the oil bolts are the same
            I dont run one on my car
            the truth is out there
            part GSI part VXR
              if you look at the std turbo it has a Oil Restrictor in the hole you put the bolt in
              so I would say no need unless your selling the car and its starting to smoke
              I call the oil Bolts a 2nd hand car sales man bolt
              part GSI part VXR
