fitting txa intercooler
  • fitting txa intercooler
    Anyone fitted this themselves? and if so how easy/difficult was it?, how long did it take?, did you jack the front end of the car up? and what difficulties, if any, did you encounter while fitting?
    Adam
    bump . . . .
      Has to be jacked up and bumper off bud makes the job alot easier
      CDTI Air Box, REMUS Exhaust,Regal Stage 2 intercooler, Dbilas cast manifold with Hybrid Dbilas GT28 turbo, Dbilas air intake scoop,EVO-MS Recirc Valve
      Regal / EDS inlet manifold and top hat with thermal gasket,630cc injectors with fuel pressure regulator and uprated high flow fuel pump
      Regal inlet cam with uprated springs and platforms,16 bar mocal oil cooler 360-380bhp
        It's easy mate I done my own, just follow the instructions and your be fine.
          do they tell you how to remove bumper etc??? (dont get cooler til next week)
            If you look on the forge website it tells you step by step with pics. I used that to fix my washer bottle
              am definitely gonna fit to avoid any extra costs, as long as the instructions tell me how to remove the bumper it should be fine.
                i didnt jack up the car, bumper camp off with a little bit of elbow grease, really straight forward fitting, providing you know where things go, need to take the crash guard off to be perfectly honest just to get aircon fan out ect. and then the hardest bit if im honest was mounting the cooler. Will take you a few hours just dont rush it. Forge have a fitting guide for their cooler on their website, i used this as a basis.
                Remus turbo back , TX enlarged tophat, CDTI pipework, Pipecross XL Foam/Cone Filter, FMIC, Forge recirc valve, Forge actuator, Regal 3 bar map sensor, HRC fuel pump, Courts coolstat , GM Breather box, custom oil catch can, FK coil overs, Whteline RARB Gloss Black Corsa VXR Alloys, De badged and de-wiper at rear. HID headlights/LED sides. Custom carbon wrapping.
                  providing i know where things go . . . . . . . . . was hoping the instructions would tell me that . . . . . . . .
                    they will mate, i didnt even use the instructions, you can visualize where things go when you have the parts in your hands, where you from? any questions just give me a buzz
                      from wakefield west yorkshire mate.
                        here you go i'm sure this will help http://forgemotorsport.co.uk/media/ASTRA%20VXR.pdf
                          oo little far for me to come help :P but in my advice if you are not sure even with the instructions get someone to give you a hand. You should be fine if you are mechanically minded. and yes look at the link above, i found it useful. bare in mind it will be slightly different as you have TX cooler not forge
                            cheers bud, will use this as a guide
                              could always use my mechanic help me out, he might want a bit of cash tho . . . . . . . .
