Hydraulic lifters, same part in vxr as others? like z20let..
  • Hydraulic lifters, same part in vxr as others? like z20let..
    Just wondered if the hydraulic lifters are the same as used across the range in many vauxhalls
    say these
    http://www.ebay.co.uk/itm/VAUXHALL-O...item20b510e77f
    state they fit the z20let, but are they the same in the leh? or did vaux use different ones for the leh.
    is there anybody that can confirm this with part numbers etc.
    I thought the let and leh were the same engine but the leh refers to different software on the ecu .
    #1
      I thought some bits where different in the leh!
        the lifters in the let fit about another 100 vaiuxhall engines so i was just wondering, any1 acess to parts number
          Hi bud if i was you i would give the Ebay ones a miss lots have had duff ones in the set's i.e. cheap crap
          give AUTO VAUX a ring i got mine from them for my calibra turbo cost around the £140 for the set and there the genuine INA part same ones as if you bought them over the counter a vx but vx wanted £350 trade lol
          QUOTE=jwfcms;1934412]Just wondered if the hydraulic lifters are the same as used across the range in many vauxhalls
          say these
          is there anybody that can confirm this with part numbers etc.[/QUOTE]
          Drives sapphire Black Astra VXR/ Calibra DTM Turbo
            i wouldt buy them from ebay.
            i have a set of INA ones.
            but they are just the ones like listed in the ebay auction fit lots of model engines. so i just wondered if they fit the leh to.
              the let and leh arent exactly the same, the leh has the under piston oil jets for one, although ive no idea about the lifters
              Stage 3 Arden Astra gone
              Stage 2 burg
                They're the same
                    Yeah matt has an LET and put some of my old LEH ones in his fine.
                    Also guys regarding the difference between LET/LEH they're based on the same design the LEH is an improved version of the LET and has many small pieces which are different. 80mm MAF, different injectors, revised turbo, different cooling line setup, oil spray jets, forged pistons, different ECU, doesn't have balancer shafts etc.
                    Clique #14
                      as matt confirmed
                      they are the same in alot of the heads.
                      Product Information
                      Hydraulic Lifter, OEM, manufactured by INA.
                      Suitable for all:
                      2.0 N/A and Turbo - Z20LEx, X20XEV, X20XER, C20LET, C20XE
                      All V6 N/A Applications - C25XE, X25XE, Y26SE, Y32SE
                      X14XE, Z14XE, C16SE, X16XE, Z16XE, X18XE, X18XE1, Z18XE
                      taken from the lifters on courts site
