whats the vauxhall warranty on paint?
  • whats the vauxhall warranty on paint?
    noticed around my right mirror on the pillar the laquor has began to "bubble" up. is there a vauxhall warrenty on paintwork that covers this sort of damage. Obviously i won't be able to claim for stone chips but was curious about this.
    cheers
    Remus turbo back , TX enlarged tophat, CDTI pipework, Pipecross XL Foam/Cone Filter, FMIC, Forge recirc valve, Forge actuator, Regal 3 bar map sensor, HRC fuel pump, Courts coolstat , GM Breather box, custom oil catch can, FK coil overs, Whteline RARB Gloss Black Corsa VXR Alloys, De badged and de-wiper at rear. HID headlights/LED sides. Custom carbon wrapping.
    ive got clear coat peel on both of my bumpers so would like to know this also.
    Done: Dap-r Springs, Whitline RARB, Black Diffuser And Fog Rings, Arden Bootstrip, Tinted Windows, Led Sidlights And Numberplate Lights
    Still To Do : Referb Wheels Anthrisite, Piper Exhaust, CDTI Airbox, ALF's
      paint warranty is 12 months, and anti-perforation corrosion warranty is 6 years
        does that cover both of us?
          Unless either of your cars is less than a year old then no. If you've got lacquer peeling/bubbling etc its likely that the affected panel has had some paint sometime in its life.
            mine is a year old in september so i should be able to claim through warrenty ??
              You should all be covered but if you have no luck with a dealer, give vx customer services a call. This seems to be a very common thing with vxrs!
