slight problem
  • slight problem
    ok guys for a while i thought i was losing water through rad leak but i went for a drive earlier and steam was coming out my vents so thought oh no and pulled over popped the bonnet and the reservoir tank was bubling over and spitting fluid out of the overflow has anyone else experienced this,level is exact and temp gauge reading 90 degrees......
    Possible thermostat sticking? Used to be common on the MK4's. ...... could be sticking shut
    James
      thx for the reply james...any other input guys
        You running a cool stat Danny ?
          have you seen if the thermo stat is working ?
          felt the pipes in and out of the rad when running .
          Does the fan kick in at 95 is it ?
          is the cold level right ?
          do your heaters blow hot ?
            no im not brian....
              Originally posted by A2ON View Post
              have you seen if the thermo stat is working ?not checked yet
              felt the pipes in and out of the rad when running .no
              Does the fan kick in at 95 is it ? will check for deffo the morra
              is the cold level right ?level on the mark
              yes they do
                Originally posted by jigger View Post
                no im not brian....
                I would fit one mate it opens around 82Deg, seems as above the OEM one could be sticking
                  seal on the reservior cap faulty maybe???
                  Had this on my old vectra GSI.
                    funny you should say that cos i had some work done and the cap was cross threaded so i just changed it over with a astra g cap little different but thought it be fine but how would that effect the water boiling up and spitting out the overflow
                      is there some better than others brian ...wheres the best place to get one m8
                        water is normally under pressure in the system which prevents it from boiling as it would normally do when in a kettle etc. If the seal is not sealing properly it will prevent the pressure building up and so cause the water to boil and spit out from the cap
                          yep get you but its not coming out the cap its the overflow but will get a new cap anyway and a cool running thermostat....
                            Courtenays do one mate, http://www.courtenaysport.co.uk/buy-...s/prod_30.html
                              These were my words exactly......
                              So as above..
