Regal cam
  • Regal cam
    Is there a noticeably difference? currently got a turbo back exhaust and tx front mount but still on standard map. So wondering what to do next either cam and map or just the map. Also will I need an uprated fuel pump at that?
    Just a map will make a good difference, the cam and map makes a huge difference in the mid range. I'm running the cam and map on the standard pump with no problems.
      Ok thanks, do you think that a 2.75" resonated system will be alright over 300 horse? And also with the tx cooler? Or would you look at upgrading them.
        The chimney will be fine as long as it has a sport cat or no cat. I can't comment on the cooler as I never got to test one.
          I suppose there's only one way to find out then . Thanks for info bud
