Best standard pads?
  • Best standard pads?
    I hear redstuff, yellowstuff ect...But what are the ultimate standard pads for fast road driving?(no track use).
    standard oe pads , my car at 265 bhp/263 lbs/ft give them pads some real testing in all condations, and held well imho
    i think if you get the brake fluid changed , it helps alot
      If you have good High BP fluid, brake cooling ducts and braided lines - you cant beat OE pads Dave IMO
        as rich said
          +1 and easy on the pocket too
          Sent from my HTC Wildfire S A510e using Tapatalk
            Well...im shocked. Thanks for the info
              need to keep them cool tho as they can over heat.
                Are the cooling ducts the ones that clip onto the wishbone?
                  yeah, think courts sell them
                    Thanks very much. Did you get your laptop sorted btw?
                      ermm kinda, had to by the back up disc, so just waiting for it to turn up.
                      thanks anyway mate .
                        sure I read on a thread Dannyf rated the police spec GM ones quite highly. Can only assume a slightly different compound, unsure if available for the astra but I know you can get them for the vectra.
                          just bit off topic .. where do i get braided brake lines for the VXR OEM brake setup ?
                            courts, tms, regal, mpg should all sell them
                              Thank you mate..
