z20let/leh which cams to go for?
  • #76
    i would think there wont be much in it
    • #77
      as the courts cast kit comes with tial stainless housing it will be perfect!
      • #78
        well spoke to the lad he can get them in i need internal gated turbo with standard garrett exhaust housing so seeing if they do them without v-band and with actuator
        • #79
          http://sites.google.com/site/z20letpower/ thats the guy who can get hold of the gtx range, only get in touch if you are serious and intend to order from him. his contact details are on a link
          • #80
            glad i held out on the courts cast kit now!should be a leathal combo with this new gtx28..
            • #81
              8 days time ATP will have the GTX28 s in stock so not too long of a wait, Express delivery is 2days.
              • #82
                i just need to see if they have the normal garrett housings available with internal gate first otherwise they no good for me
                • #83
                  Although as usual the Americans will get them first before any uk buyer will be supplied..
                  1150 with housing seems mighty cheap..with housing too,import tax,carriage..sounds too cheap..
                  • #84
                    should be a pair of monsters by summer
                    • #85
                      thats all included in the price as he gets them at disscounted price. the gtx2871r is only 1200 dollars add 300 for housing still comes in at £1000
                      • #86
                        so lets assume the regal cams are 9.5 lift?? and we know the courts cams are 10.6 lift,what differance would you see on a fully forged engine running a garrett gt3076 at around 450bhp between the cams(or around 1mm extra lift)??
                        • #87
                          That I could not answer other than a bigger turbo requires more flow. More valve lift gives better flow
                          Cams I'm getting are 10.5mm on inlet 10mm exhaust and powerband 1800ish rpm to 8000, slightly longer than 270duration
                          • #88
                            to decide that you would ideally need to know the duration of both sets of cams and the overlap would come into effect aswell
                            but if durations were the same i would expect both cams to act the same in the lower rev ranges but up top the larger lift cam would show more power in the higher revs
                            • #89
                              Not sure about courts but Steve's ate 10.5mm lift and 270* duration HTH
                              Tech 2, Cruise Control, Anti Hijack, Check Control, Board Computer And Divorce & Marry New Radios & Screens In & Around SouthWest London/Heathrow Airport. Pm For Info
                              • #90
                                Yeah 10.5 inlet 10mm exhaust on steves. Going to order them at the end of the month with the gtx2871r turbo minus the exhaust housing. Boooost
