has any body fitted a dump valve on an astra vxr heard it is a bit more complecated than other turbo engines any help would be great :wink:
help with dump valve
Im not the best person to advise you but i believe Courtenay have done dump valves for the VXR.
You should give them a call.
hi yes i do have a DV fitted its fine not hard to fit you just have to make sure the vac trigger pipe is fitted in the right place .
the pip work is under the txt box on main pic
yes i did fit it my self took about halt hour,just make sure the vac take off is from feul presure regulator and all will be well.
ok mate jon will sort you out no worries there.
