Screen
  • Screen
    Has anyone else discovered the screens 2 settings ones night and ones day. The astras sceen is set on the night setting to start off with but go into setting and then display and you can make the screen orange with black writing when your headlight are off and black with orange writing when your headlights are on!!
    Re: Screen
    how ???????? what cd system you got in ?????
      Re: Screen
      I have the MP3 CD system, To get night and Day go into settings then display and then night and day switch
        Re: Screen
        thanks will try it in a bit
          Works even better on the CD70, although the day screen white background is a bit bright.
            Re: Screen
            only have the cd40 in mine have tried it on mine but could not get it to go in to display,have you got sat nav ??????
              CDC40
              mine has 3 settings.
              Day.
              Night.
              Auto.
                Re: Screen
                N, No sat nav
                  Re: Screen
                  N, No sat nav
                  how do you get it in to display settings ???????
                  mine just comes up with clock sync ????????
                    Re: Screen
                    N, No sat nav
                    Press the settings button and you should have 2 options audio and display.
                    select display and you get more options pick day/night.
                      Re: Screen
                      N, No sat nav
                      only get system or audio on mine,given up now but thanks for your input
                        M Parkes.
                        CDC40.
                        Press Main.
                        Press Settings.
                        Scroll Down to Day/Night.
                        Select.
                          Originally posted by alex_c
                          M Parkes.
                          CDC40.
                          Press Main.
                          Press Settings.
                          Select.
                          thanks alex tried again but only get audio or system ????????nothing else
                          might be passing your way on thurs as going to courtneys to have some tweeking done to the beast
                            PM sent bro.
                            Call me and i'll help
                              PM sent bro.
                              thanks for your help alex
                              silly me only cd30
