Which turbo kit should I get for z20leh
  • #16
    Originally posted by VXR.Dan View Post
    My nortech mani. So much nicer than the courts cast crap. Courtenay have made the cast mani saying it will never crack like a tubular. Find me a nortech mani that's cracked on a vxr?
    thats easy I know of a few that have gone back to get fixed or replaced on Z20LEH engine's
    I like the cast setup for a road car my self less hear put into the engine bay ect ect
    the truth is out there
    part GSI part VXR
    • #17
      taking the fact that you use your van as your daily driver into consideration i would lean more towards cast due to reliability and also the fact that they deal with heat a lot better, both being plus's for a daily driver in my opinion. Tubulars are certainly more susceptible to cracking due to heat and vibration so i would ask yourself this, IF you go tubular and it cracks can you afford to potentially have the van offroad until it is sorted?
      on a side note if your going omex just check it can deal with drive by wire (e-throttle) or you may find yourelf having to change to a cable throttle
      • #18
        Its such a had decission, for omex I have bought, new throttle pedal from an early astra x20xev cable and throttle body also coil pack with leads so should be ok.
        does anyone know the price of a gtx3071
        • #19
          the cast kit will run 600bhp as proved by klassen,it will not crack as easy,it will give less engine bay heat and is alot tighter to the block so clearance for rad/fans is better..granted it looks boring up against a nortech but theres now a good solid quality cast option on the market if thats what you want.
          • #20
            Are you getting a cast mani Shane?
            • #21
              Sorry to hi jack the thread but where can you buy GTX turbos and do nortech have a website?
              Edit: Found it http://www.nortechperformance.com/ and http://www.turbodynamics.co.uk/
              Arden Astra VXR
              GCAP Stage 4
              • #22
                in time yes dan with ceramic coating..
                • #23
                  Nortech mani. There kit is top quality. plus the heat under the bay isn't as bad you'd think.
                  Daily Mk7 Golf R - Nortech Corsa Track Car !
                  • #24
                    Ughhhhhh shane. Noooo
                    • #25
                      700 unoficially I had a long chat with Stephan and decided to sell my nortech mani and went for the cast, my car is also going to see allot of road, tho 90% track focused the cast mani suited my needs better and no risk of cracking. That said ive never heard of a Nortech manifold cracking when braced correctly!
                      I think its safe to say theres pros and cons for both, just what suits your needs better, i wouldnt say theres a better out of the two....
                      Tech 2, Cruise Control, Anti Hijack, Check Control, Board Computer And Divorce & Marry New Radios & Screens In & Around SouthWest London/Heathrow Airport. Pm For Info
