Windscreen misting up at the bottom inside.......
  • Windscreen misting up at the bottom inside.......
    Since it's started getting colder i have noticed that my screen is misting up at the bottom where the vents are at the top of the dash.
    Anyone else get it? And how do you get rid of it? Turning on the fan onto the screen doesn't help.
    turn on air con. problem solved.
    STEALTH
      I Get The Same
      Hello,
      I am getting the same thing because i still like the car to be a nice cool temp. So i have my aircon on low and i think cos the outside air is cold and the inside is cold it starts to almost ice up. I get that alot on my way home from work cos i work nights and its really fresh in the mornings. Warm the inside up with the air con and it should go away.
        I get it too
          Turn off the air con so that the ECO sign is displayed, it will then not occur
            This happened on my vectra as well as the astra, but mine is usually on the outside. I find turning the temp up slightly helps rather than full aircon, I like a cold car as well, hate the heaters on !
              Oh right, thanks for that folks, i'll try that next time it does it.
              What's the ECO thing all about though? Is that for the climate control? I have just got the normal heaters.
              Ta
                Originally posted by Police_Driver
                I get it too
                well dont have WPD CAT in the car with you then
                Simple.
                    LMFAO.
                    Now thats funny PD like it alot.
                      check out the m3 thread on your astra forum, even better
                        ok will do
                          vectra is the same
