ANY PDI PROBLEMS
  • ANY PDI PROBLEMS
    picking up my black vxr brand new on monday morning is there anything i need to check for which any of you may have come across picking it up in chesterfield looking forward to the drive home to liverpool
    excellent forum
    other things to look for
    Examine thoroughly Alloy wheels especially 19s
    *Check for that elusive B Pillar trim ( Carbon Effect For 07 MY )
    *Check the engine is well cleaned (or you'll be convinced for weeks you can smell petrol)
    *You have some fuel!
    *Side skirts firmly attached
    *Check your looking at the right car
    *Check to see if Glovebox tray is included ( This item may be deleted in the 07 Model )
    *Check the mats are there
    *Check the Valve caps are on the wheels
    *Check paperwork thoroughly, finance docs, registration etc.
    *Check for emergency tyre repair kit
    *Check exhaust end that its sitting in the bumper cut out and not dropped
    *Check weather strips are on under leading edge of bonnet (Deleted I believe for the 07MY)
    *Check condition of Seat Bolsters, the leather can be creased on the Outer Drivers Bolster
    *Check that the 'TRANSPORT BLOCKS' have been removed from the front suspension springs!
    *Check front and rear skirting, has been known to scrape on some coming off the transporters
    *Check Delivery mileage is reasonable
    *Check rear bumper is attached both sides
    *Check any RECALLS have been carried out - only one i believe outstanding for VXR at the moment is Wrong spark plugs
    *Check the Black wheel bolt caps havent been 'Bleached' white by the valeters Wheel Acid!
    * Check badges "VXR" in chrome are attached to both doors in line with bump strip ( New for 07 MY
