what best to go for lowering
  • what best to go for lowering
    What is the best to go for in springs, i heard eibach are prob best. is it ok to just uprate the springs with standard dampners, will this not affect the geometry in any way
    Re: what best to go for lowering
    I have Eibach Pro-Kit on mine purely because its been TUV tested in Germany to work properly with the IDS+ system and isn't a bigger drop as some other spring sets.
    If you don't have IDS+ KW and KONI are also both quality brands.
      What springs
      which springs do people think are the best to go for and what drop is advised for best performance, so far been advised to go for -30mm eibach ones, but what about apex, koni etc etc which is best. any help !
        Eibach on the std shocks im fine.Fitted my self easy job.
          How much is that lowering you by?
            Someone did say £120....
              about 20mm rear 30 front
                can the eibach pro kit be used with vxr with and without IDS?
                  Yes it can - they also rebadge their springs for IRMSCHER
                  Ring Eibach up for a chat if you have any concerns - they are very helpful and well informed
                  01455 285852
                    I also have Eibach pro kit on mine,works very well. I bought mine from the biggest Opel/Vauxhall tuner in Germany,Steinmetz.Very good on the road,even do im on studless wintertyres now in 18inch.
                      wat do people do with the standard springs when they have upgraded to others?
                        if i wanted to choose a spring kit with a lower drop than the eibach ones which could i choose
                          what is the diff between eibach sports and eibach sportsline do the later lowere more or something
                            look at this
                            https://www.lmfvauxhall.com/prodCata...8&deptIndex=14
                              cheers. think im going to order a set of the pro kit eibach's after lunch can someone pls be so kind as to tell me which weight ill need, as i have not got the car yet and cant check myself
