Error codes...
  • Error codes...
    Hello,
    Got a few error codes and was wondering what they mean and how to fix them? Any help would be much appreciated, thanks.
    P156571 interface speed control dysfunction CRC (electronic speed control) B-006
    P023505 boost pressure signal to donors large C-031 / too small
    P070404 clutch switch error /clutch switch dysfunction CRC (electronic speed control) B-010
    No P013658 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-027
    P0136 lambda probe dysfunction (Bank 1 Sensor 2) B-027 / lambda sensor circuit not in the target area (Bank 1 Sensor 2) B-026
    P0136 O2 sensor circuit voltage high (Bank 1 Sensor 2) C-023 / O2 sensor circuit voltage low (Bank 1 Sensor 2) C-023
    No P013022 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-020
    P0130 lambda probe dysfunction (Bank 1 Sensor 1) B-020 / lambda sensor circuit not in the target area (Bank 1 Sensor 1) B-025
    P0130 O2 sensor circuit voltage high (Bank 1 Sensor 1) C-019 / O2 sensor circuit voltage low (Bank 1 Sensor 1) C-019
    No P013004/08 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-020
    P0130 O2 sensor circuit voltage high (Bank 1 Sensor 1) C-019 / low (Bank 1 Sensor 1) C-019
    No P013601 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-027
    P0136 O2 sensor circuit voltage high (Bank 1 Sensor 2) C-023 / low (Bank 1 Sensor 2) C-023
    P007072 sensor ambient air temperature dysfunction B-024
    P011014 intake sensor signal is too large C-008 / to small C-008
