Is this normal?
  • Is this normal?
    Had my 07 Astra VXR for about a month and covered 700 miles, but noticed from new that the engine is quite 'buzzy' from 3000rpm upwards (below 3000rpm it's dead smooth) on the over-run and when cruising.
    I can feel the 'buzziness' on the over-run and when cruising above 3000rpm through the pedals and floorpan - it's not a huge issue and doesn't feel mechanical...certainly not there when the engine is under load (accelerating).
    Is it normal - is this what other VXR engines are like or is mine different i.e. is there something wrong???
    Perhaps one of the tuners could comment as they probably have more experience of different VXR's than anyone else??
    I know, for example, that Vauxhall have removed the balancer shafts in this engine to improve response and the ability to rev - is this the trade-off?
    Loving the car by the way. Traded down from an M3 - best thing I've ever done. So much ability for so little cash (relatively) - awesome
    Do I just need to get it run-in properly???
    Cheers in adavnce for any helpful replies.
    Andy
    HOWDY DIDDLEY DO NEIGHBOUR , EXPLAIN BUZZINESS ???
    IM UNFAMILIAR WITH THIS TERMINOLOGY ??
      So, 18 VXR owners (at the last count) have read this thread and no one has offered any sort of input
      I only need to know whether other owners experience this or not. If not then I have an issue and I'll let Vauxhall tell me what is wrong - I'm not looking for a diagnosis, just whether others have similar experiences?
      C'mon peeps...help put a fellow owners mind at rest
      Andy
        High frequency vibration under-foot whilst cruising or on the over-run above 3000rpm- feels like a natural order of vibration for the engine to be honest but just want to check that its normal?
        Andy
          OK, here's a real stupid suggestion, but its happened before... check all the transportation blocks have been removed from the suspension.
            get it checked by a dealer it might be nithing but you can never tell
              No transport blocks - checked that on collection...
              Cheers for the suggestion though.
              Andy
                I dont think i get what u are trying to explane sounds ify to me i would get it back get it check out have u checked the wheel nuts a tight as been know
                  Where are you located, might be another [veteran] owner near you that may be able to give you a second opinion
                    It's a certain harshness to the engine above 3000rpm on the over-run or when cruising that isn't there below 3000rpm.
                    This help?
                    Andy
                      check the black vac pipe the leads to the turbo make sure this is ok. it as been know to come off or split.
                        I'd suggest trying to have a run out in another VXR, compare it with yours, I don't notice any vibration etc, very smooth car really
                          Never noticed anything vaguely like that on mine... get it looked at!
                            Originally posted by R20 VXR
                            get it looked at!
                            Agree - That's what the warranty is there for.
                              get it looked at!
                              Definitely...doesn't sound healthy does it?
