Need Help...
  • Need Help...
    How do you get the the Temp of the Engine TEMP on the screen, ive tried the settings til it went Bleep then the bc Button 4 times and it didnt work, thnaks guys .....Bhav
    Re: Need Help...
    Umm....I think that is correct. Once you hear that beep it should say test or diagnostics mode. You'll need to come out of settings mode but then pressing the BC button several times you should see some new screens. One of which displays the coolant temp.
    Unless of course you have a newer model (06 or 07) and that function has been removed!
      i got the my07 model and i can get it on mine on a cd30 model jon at courtneys showed me how to do it but it's just a letter with another letter in front but for the life of me i cant remember what the letter is :?
        try this
          is it how i said bro cause if its not i'll change it
            only picked her up today so it must be a 07...
              Cant see what diference it makes if its a 05 or a 07 the system is the same did you follow the how to i did i think 240 also posted it on here
                Not necessarily. New versions of components come out all the time with new or remove features.
                For instance, my car will tell me when the washer fluid is low, 06 and 07 models don't.
                  yeh just a different pic from yours tho alex mate
                    mine does when it's empty and nothing comes out i know iyt's time to waz some water in again
                      Im Thick Still cannot get the temp on the screen...sorry
                        did you follow the how to.
                        if your still having trouble then a pm sent.
                          Cheers mate will call 2moro, Im too Thick to get the temp up... cheers mate
