A extremely dangerous abs fault!
  • A extremely dangerous abs fault!
    Hi guys,
    It's been a while since since posted on here. Probably because the car has been behaving so well until yesterday.
    It's developed a real dangerous problem. I'm driving yesterday very calm when suddenly the traction control light started going crazy and the abs lights flashing but also braking harsh on its own. This is continuos on all my journey. Don't even have to touch my brakes.
    Cut long story short a month ago had a new cim unit fitted in the dealers. Every now and then the abs light and traction light be stuck on at first when car is started. I drive 10-20 yards they go out.
    Would the cim unit be the cause?
    I also suspect a small knock when breaking when reversing and it's coming from back drivers wheel, possibly wheel bearing?
    Just want clear this problem before I even take my kids in the car.
    No fault codes stored
    Pads are near new
    No idea of what is causing the issue but I certainly wouldn't be driving it, needs recovering to the garage for them to investigate further.
      Going to take it off the road for a month use the shitrun.
      Think May be wheel bearing gone.
        mine was a t3w wiring loom that got some water in when i jetwashed it... replaced that and all sorted now
        Previous Owner of the Carbon Edition VXR - Stage 3 [Airtec + Remus] Carbon Alloys and Rocker, Blue 356mm Ksports, Roose CDTI & Black Samcos, PPP Tophat + Boost Pipe, Quaife LSD, H&R Race Springs, Black Whiteline RARB, Blue SMD Conversion
        **Audi R8 FTW & Progress thread**
          Where to is that wiring locatated. Worth checking it as we have had a shed load of rain latley
            could be the sensor on the wheel bearing thats broke maybe
              in the arch mate... comes out of the hub and into another plug near the arch lining, open it up if its rusty on the prongs its that
                Just an update. My problem was a faulty abs sensor. They're built into wheel bearing as most may know. New wheel bearing kit job.
