Bigger rear brakes?
  • Bigger rear brakes?
    Probably more one for the tuners, had the idea of fitting rear disc set up off the Saab 93 aero, also fitted to the large engined vectras iirc, they use what seems to be the same calliper (yet to check against mine) with a different carrier. They are vented 292mm/11.5in diammeter 20mm thick disc. Anyone looked into this or able to confirm the calliper is the same?
    luke
    rear brakes
    Bigger kit allready done and on the Astra VXR sprint car at VXRPC
    Very effective, ask Sparky, Jon at Courtenays and a few others who sampled Vxr Astra braking forces at Snetterton last August.
    Prices to be released in January as Special adapters are required for mounting.
      thanks for the info, was looking at some way of filling the void that the 19's make around the rear discs
        Re: rear brakes
        Pics please of the rear set up ???
        What £ and hopefully they match the AP front disk pattern ???
          The discs are not grooved, they are vented, grooves are not needed, they only cause more noise on the rear.
            Fair enough !
            Are they a complete set with new calipers {both colours} etc & what is the price etc ???
              Prices out in Jan 07
              blue and Red
              complete, disc, bracket ,caliper ,fixings and brake pipes.
