milltek rear section
  • milltek rear section
    is the milltek rear section (exc cat section and front pipe) easy to fit Diy and the old standard one easy to take off? any specialist tools required? thinking about fitting it myself.
    PM sent today
      im hoping to end up with the full milltek system but due to expense im going to do it bit by bit cat back, front pipe then sports cat section, however will i see or notice any improvemnt initially with just cat back over standard.
        also anyone fitted the front decat pipe them selves?
          anyone know abouth the front de cat pipe for DIY fitting?
            Hi There
            Yes really easy to fit yourself matey, although i did have the benefit of a pit etc. Be careful though as some replacements do not use the original studs and you need to purchase your own bolts etc. Although most do have the studs i believe. The regal ones don't however !!!
              do the courtenay pipes come with bolts etc
