HEADLIGHT ADJUSTMENT
  • HEADLIGHT ADJUSTMENT
    :? How do you manually adjust headlights nearside and offside Main and Dips for vertical and lateral movement.
    [Standard lights with Vision plus 50% standard wattage bulbs fitted]
    I can see the adjustments [X4 hex holes both sides above the lights] but it appears its for left and right only [lateral only.] Where is vertical
    Safe Driving ! Andy
    There is no option to do this on the VXR, the beam is set permanantly.
      The beam can be adjusted with Tech 2 on the Xenons at least, not sure abotu the standard lamps but I would imagine that its the same.
      Nova 1.6 16v TB's DTA 1/4mile 14.8s
