IDEA'S ON BULBS!!
  • IDEA'S ON BULBS!!
    just after some idea's on the best bulbs to buy side and headlight?? how hard are they to fit?? and were can i get them?? cheers guys & girls
    oh! and if poss the numbers for them :?
    bulbs
    hi mate
    i got philips blue vision( main beam)and p.i.a.a xtreme force(dipped beam)they are both blue bulbs and give fantastic light at night,i got the philips from powerbulbs.com and the xtreme force from ebay.the dipped beam is quite easy to fit thru the engine bay but the main beam have to be accsessed thru a panel which is located in the front wheel arch to the front of the wheel you will need to turn your steering wheel as much as you can so the wheel is moved out of the way so you can access the panel this is a little more difficult you will need a torch or a spare pair of hands,alternatively you can remove both front wheels i will do this next time but you can change them without doing this but just be carefull and patient!
    cheers
    nick
      have you got the model codes for the bulbs??
        bulbs
        yes mate no problem they are H7 dipped beam and H1 main beam.
        cheers
        nick.
          cheers Nick, i've found those sites, much appreciated!!
            has anyone got the code number for the spot bulbs please???
              H11
                look hear
                http://www.vxronline.co.uk/messagebo...=1928&start=15
                  cheers dave
                    are they easy to fit??
                      yes theres a platic flap in the wheel arch for the outer lights the main beam is done under the bonnet and the fogs from under the front car needs to be jacked up
                        its just the fogs i need dave!! i had a look on one of your links from another thread, i think it is were you bought yours, when you click onto it it takes you to ebay. But i noticed that it advertises them as H11 but on the actual bulbs it has H3 on the packaging is this right?? :?
                          yes that just a show pic the bulbs are H11 for the fogs H7 dip beam
                          H1 main beam and 501 for side light bulb
                            and are they blue??
                              i just noticed it says H3 on the item description aswell!!! I wouldn't keep asking you about them, but i can't seem to find any H11 bulbs anywere
