DOWN PIPE NO MORE
  • DOWN PIPE NO MORE
    Dazturbo6502 car now sounds even louder than ever, think this has been sorted by now, but still of intrest.
    Bad work Milltek
      could have been caused by an hairline crack in the weld then with the vibration it just travels , and b4 you know it plop its off looks like it's done that as it's all 1 side of the weld needs doing by a proper welder
        Was Very loud.
        Standard Front pipe is on at the moment and Thorney has organized me a replacement, which i shall fit when it turns up
        My VXR from Start to Finish
          most of the exhausts these days are done on machines by robots only has to be a mm out of line and b4 you know it this happens a small pin hole in a weld dont take long to travel
            Glad i had a CS one it looks better as well and is mad from less parts.
            Far superiour quality.
              Is this another minefield?
              Daz would like to pop down and see you when my new car turns up.....
              Hope you get it sorted!!!
              Oh and lets keep this thread civil!!!!!!! :wink:
                Wasn't it the same thing that happened to the VXR that is in the back of the Top Gear magazine? If not it was a fault like that somewhere.
                  Yes mate, that would be good :wink:
                    Yes mate, i believe it is the same thing that happened to that car
                      As I posted on the other thread......there have been 4 failures on 2 cars and all have been replaced under warranty. We've since investigated and made some changes to the design and fabrication. Any failure is unacceble of course but the number is very small considering the numbers out there (over 250).
                        with any part which is welded there is a chance of hairline cracks not just the vxr exhausts could happen to any exhaust any where it is welded just a very rare occurence so i wouldnt worry about it
                          Yeah I have been reading thier exploits since they got the car, it was the same failure but not as spectacular as this, still its got a lifetime warranty and Thorney says its being sorted
