Technical Advice please, from vx techs and astra VXR owners.
  • Technical Advice please, from vx techs and astra VXR owners.
    Hi there,
    Does anyone know the PCD Size on the astra VXR? (size between wheel studs centre to centre)
    Reason for asking: I am buying a brake upgrade for my astra VXR, was looking into the AP Racing kit, but when in the dealer looked at a 56 plate Monaro VXR and the front brakes are exactally the same secification as the AP kit(grooved discs, same diameter and four pot calliper configuration) If they fit i would get the VXR monaro ones as thay are probably supplied to VX by AP anyway, and i get partners discount on parts which is very good, i would get a few hundred pounds off the set from VX, so hence why im looking into compatability,
    Any help much appreciated.
    Monaro Wheels
    Diameter: 18" (CV or 19" (VXR)
    Width: 8" (J)
    PCD: 5 x 120mm
    Offset: 48 mm
    Bore: 69mm (note: check your car as there are some variances)
      thanks for the quick reply BO55 VXR, exactally what i needed to know, does anyone know if these measurements are the same for the astra VXR?
        pcd on the astra is 5x110 and the bore is 65mm
