Courtenay silicone hoses???
  • Courtenay silicone hoses???
    Just a quickie. Are they easy to fit or would it b safer to get a proffessional to fit them
    yes mate thay are easy to fit just make sure u do them up nice and tight.
      Luvely jubely. Thanks for that
        do they breather hose fade in colour after a while?
          Get some decent pipe clamps to fasten them with, easy to change but as has been said, make sure they are fastened up tight.
            no but your car will
              black fades does it
                mine doesnt
                  All i wouls say is it might be easyer if you place the big end of the hose from the AMM to the Crossover pipe in warm water to soffen it abit as some can be very tight to fit and this will alow for a better fitting.
                    i had a feeling that bit was gonna be arsey.
                    stage 2 vxr
                    [email protected]
                      now theres no need to be a*al about it....
                        Tango
                        Wisky
                        Alfa
                        Tango
                        You can some times be Alex.
                        I was only trying to asssist the chap in sliding it on easy with out lube.
                          I am gunna get some of these, can you get one just for were the dump valve goes
                            yes you can.
                            www.courtenaysport.co.uk
                            :wink:
                              Thank you
