turbo timer
  • turbo timer
    any one got a turbo timer and if so where did you get it from?
    I dont think you can really wire in a turbo timer due to the CAN - BUS wiring system.
    To be Honest its not really needed.
    Either Allow the engine to idle for at least 30 seconds after stopping, or simply drive gently without allowing the Turbo to boost for the last couple of minutes of your journey
    My VXR from Start to Finish
      be very carefull m8 , i would advise against personally :?
        As daz as said mate the cam-bus system is a real pain, just let it warm up run down.
          There is no need for a turbotimer in modern turbo engines.
          What I do when I have worked the turbine for a bit is go slow for the last few miles (under 3000 rpm) then let it idle for around 30 seconds and everything is cool and quiet :wink:
          Blue Arden Astra OPC
