boost gauge water temp
  • boost gauge water temp
    just fitted today gauges from auto gauge e bay
    Nice work Dave
    Like them
      i like the gauges just not sure about where they are mounted nice and tidy though
      heres where my boost gauge is, although it was out of my gsi so need a new one to match the vxr clocks. (also need to replace the yellow airbag wiring harness i borrowed off a warranty return )
        v. nice dave they match really well,
          They Match well Dave, i like the gauges, just not so sure on the fixings for them.
          Each to their own i suppose
          My VXR from Start to Finish
            this is the mk 2 version could well be a mk 3 will have to see, good thing it can be remover at any time with no trace it was there.
              lovely dave nice garage too when you setting up for doing everyone else's ?
                worsy check your pms just sent sign strip
                  Obviously the boost gauge is easy to fit, but what was the Water temp one like to wire in?
                    daz its easy mate the hard bit is finding some were for the sencer to go, as the ones on the car not easy to get to and if u did tap in how would the cam bus react. from what ive found you have two options tap the thermastat housing when fitting cool stat or one of the pipe joiners you can buy from ebay with hole in already.
                      Sothis is why Mrs Dave has not seen you for the last few days.
                      Nice one mate glad you got it sorted, does look good.
                        cheers buddy hows it hanging
                          not as good as you.
                          But come on the Mighty Mighty ARSENAL.
                            i had these gauges in my last car and i tapped into the blue wire from the water temp gauge to the clocks.
                            turned out the sensor must have been different because it never worked, but the temp displayed ok on the origional dash clocks.
                            have you had them working dave??
                            ps... i got a brand new (still boxed) oil temp gauge to match them going cheap if you want it :wink:
                            stage 2 vxr
                            [email protected]
                              Dont tell him that he did have that idea as well but i think he put him self off.
