inverting the throttle body
  • inverting the throttle body
    just been speaking to someone at trac art and they said something about inverting the throttle body, anyone know anything abouth doing this
    quote>
    All that is required is to remove the throttle body, make mod’s to the loom, then refit 180 degrees around the other way… so that the butterfly doesn’t upset flow…
    sorry meany INVERTING not incerting lol
      they dont have throttle's
      they have fuel injection????????
        so wat are they talking about then
          your guess is as good as mine
          i have no idea.
            just emailed them to ask ill wait reply
              So how is the airflow increased when you put your foot down??
                thay do have a throttle butterfly thats what he means.
                  ah that could be it then nice one dave, anyone think its any good
                    use to to a thing like this on the V6 vectra.
                      Not really, the butterfly is there for a reason. Dont ask me what it is. Somrthing to do with the cold weather or something?!
                      The 2L XE engines had them too and they were removable, virtually no gain!
                      Possibly worth doing if you were going to do it yourself, but not worth paying to have it done IMHO
                        its just under the top hat, if u remove the pipe between the top hat and the transfer pipe with the map sencer in it you can see the butterfly. its controled by the acc pedal.
                          is this really worth it seems like it could cause all sorts of problems
                            Changes
                            | Find | Watch | Follow |
                              Re: inverting the throttle body
                              quote>
                              90 degrees may show some improvement(doubtful though) as the throttle plate will be pivoted in the same direction as the airflow from the tophat.
