Brakes
  • Brakes
    So have picked up my K Sports and now want to get new discs and pads for the rears, what are you guys using?
    sigpicAstra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    Ferodo DS2500 seem the ones to go for with that set up
      Can't find them for the rear mate
        Maybe not for the rear, just fit something else like Yellowstuff on the rear
          Yes same as Ry, fit yellow stuff and standard discs . I went for the Courtney grooved rear discs to match the front k sports, and fitted braided rear hoses
          Arden Astra VXR WGM350 stage 4.5
          Progress thread.......Instagram Chris.Lee 1973 http://www.vxronline.co.uk/forum/sho...uilt-Astra-VXR
          W G Motorworks
            how good are these ksports over say standard
              That sounds like a class set up
                Works well with the ds2500 front pads, defo put them in for track use
                W G Motorworks
                  Yes will be changing for DS2500 for next year but for the winter will use the yellow stuff ones that came with the brakes
                    I have the Vectra VXR rear brakes on mine, a vast improvement over the astra setup, normally only notice it when really hard braking as the brake bias is more front than rear.
                    Russ
                    The Red Baron Progress Thread
                      Russ
                      Was much modification needed to fit them?
                      Big Build Astra VXR Instagram - Mattyslost[/COLOR]
                        using standard on mine
                        Originally posted by Bobbyp90
                        I am pretty awesome.
                        BOOM
                        the Moaning Mod
                        Clique No: 7
                          Have managed to find a set of DS2500 for the rear so will be using them
                          Is tempting to get the bigger set of rear brakes but money could be spent on better things
                            Nope, just get the kit with the caliper carriers and braided lines and you should be good. Some people modify the stone guard on the rear but I just removed them on mine.
                            Russ
