Gearbox Troubles
  • Gearbox Troubles
    Hi all,
    Hoping someone can shed some light on my problem....
    Mostly when reversing/driving out of a parking space, when I go to pull away I seemed to get a jolt/clunk on the passenger side like it wasn't engaged into gear properly and then locks in.
    This got a bit worse over time and now if I drove round a left hand corner it would just jolt and jump and bang and then when I straighten up it would be fine.
    Also when going around a roundabout it hated it, it would go a little tight and pull back to the left a touch.
    I jacked the car up yesterday and took the wheel off, I could spin it so far and then it would lock (this is with the car in neutral!) video here - https://www.youtube.com/watch?v=iQJOm1GM5CU
    Is this a dreaded bearing failure or is there a fault with the diff or something?
    Any advice would be muchly appreciated!
    Thanks,
    Rob
    Anyone?
      Give Halifax Gearboxes a call mate. Give them description and they might be able to help over the phone
        Thanks, I'll give them a shout
