What is this noise..?
  • What is this noise..?
    Hi guys,
    I've been having a funny noise while driving and it's coming up more frequently now, it's like a metallic scraping noise, it originally came from the right hand side of the car when i was on full lock. More recently it has been happened when braking, left lock right lock.
    It sounds terrible and I feel like the car is falling to bits..
    It's due for an MOT in January and I'm dreading it at the moment.
    I've been told it could be, the backing plates to the brakes, worn brakes, bearings (already been checked and they're fine) , the plastic headlamp covers (although I would think this wouldn't be a metallic scraping sound).
    Do you guys have any advice or has anyone had this sound before?
    Arden Blue H
    Yellow JS crossover delete, PiperX cone filter, Cobra 2.5" Catback (Non-res), Heko Deflectors, MTEC Blue H1&H7 bulbs, LED conversion, Courts turbo heatshield, Double Din , Alpine 9" subwoofer..
    Droplinks are worth a look. They sound horrendous when they go
      Is it an expensive job do you reckon?
      Arden Blue H
        No it will more than likely be the stone guard behind the front disc. Put it on full lock get under with a flat blade screw driver and bend it away from the disc. Easy fix.
        Sent from My S6 edge
        Rabbid Stage 3, Airtech front mount, GM Hids, Cobra Exhaust, Direct route ram air, EBC Disc's, Red stuff pads and Hel brake lines.
        The list goes on
          The list goes on
            Thanks very much, what a star!! will look at this when it's a bit drier
            Arden Blue H
              That bit massively Cought me out scraping like mad didn't even know it was there haha
              Stage 2, Remus, DAPs, direct route aem, de badged, double din screen, wind deflectors, tints all round, gloss black fog surrounds window trim boot strip and all honeycombe, insignia washer jets, led side lights and 6k hid kit.
                Got a feeling that could be my noise! What do you think Ry? Only started happening after I got the camber corrected.
                Big Build Astra VXR Instagram - Mattyslost[/COLOR]
                  Nah, yours ain't droplinks mate I don't think
                    Meant the stone guard rubbing?
                      I'll try and get a video tonight of the sound. Sounds awful makes me cringe haha
                      Sent from my rectangular life stealer
                      Arden Blue H
                        Just had a quick look under the car, jacked it up so I could move the wheels and the passengers side was scraping. Got under and found the backing plate, bent it away and the noise went. Thanks for the help guys!!
                        Arden Blue H
                          That noise is nearly always that plate. First place I always look.
                          The list goes on
