Turbo or coil pack?
  • Turbo or coil pack?
    When I drive my car and it hits 2 and half thousand revs my engine judders and there is no power kicking in. It's asif the turbo isn't kicking in at all. I can Rev the car as normal in neutral, it is just when I'm in gear. No smoke from the exhaust or anything like that. Just the engine judders and has no power above 2 and half thousand revs. It did this for 2days then it was fine for a day, nothing wrong at all but now it has started doing it again?? Any ideas what this could be please??
    Could be number of things. Any eml lights at all?
      What do your spark plugs look like?
        check spark plugs and coil pack ,I had a similar problem and turned out to be coil pack ,good luck
          Same, but my coilpack metal contacts were covered in dirty oil so cleaned them up and ran fine again.
            it's worth checking your rocker cover gasket ,they are common for leaking as well
