Help- Error Codes
  • Help- Error Codes
    I have a standard Astra Burg. Just had gear box re-conditioned and when I got the car back the EML has come on with these codes;
    01410d
    014102
    014104
    I found this below for these codes but if i'm honest I have no idea what it means and how to fix it.
    Any Advise?
    P0141 lambda probe heating voltage is too big (Bank 1 Sensor 2) B-013
    P0141 lambda probe heating voltage is too small (Bank 1 Sensor 2) B-013
    Also
    13604
    13608
    I cant find anything for these codes.
    Any help would be great.
    The error code thread in "How to" section tells you how to read the code and the error discription
    Ignore the last 2 digits and put P0 in front of the codes and you get P0136
    Astra
      01410d
      014102
      014104
      Any Advise?
      Also
      13604
      13608
      possibly lambda not connected ? check wiring to sensor
      Back Once Again Like A Renegade Master This Time in Black So It Must Be Faster
        Cheers all. I've checked today, lambda is connected fine but the spacer has not been put back on when all connect back up after re-con of gear box.
        Hopefully get that bk on and might sort the problem. If not will try a new lambda sensor. 👍
