Replacement of front brakes and pads??
  • Replacement of front brakes and pads??
    I'm replacing my front brakes next week because as I drive there's a constant warping noise and like a judering feeling when I brake , Iv had the rear brakes replaced but i can only be the front ones ... Anyone know the best set to buy ? And what advantages it has ? Driving a nürburgring astra
    MTEC do decent discs for the money. They also sell pads if you aren't fussed on a upgrade. If you want something a bit better then a set of EBC yellow stuff aren't bad at all.
    You can do more like upgrade brake lines and add better fluid, these make a much better set up
      as above.
      MTEC do good discs and you can normally find a package deal on fleabay for them for example:
      http://www.ebay.co.uk/itm/Astra-VXR-...gAAOSwymxVIuVF
      they also do black edition ones. dont really know the difference apart from the colour and the price but if you just want the car runnng fine for now that link is a good start.
      Hope this helps
        The black editions have a black coating around them so they don't rust. Obviously the black will come off where the pads rub.
        Regal Inlet Cam, (nice and lumpy idle) Pre Cat Delete, Fully Forged by WG Motorworks (Wosser 86.5mm Pistons, Molnar Conrods, Stem Seal Retainers). Crossover Delete Wtih RAMAIR. Rear Vibra Fast Road Mount, Polybushed front and gearbox mount, MTEC Dimpled and Grooved Discs with Brembo Pads Standard map Goodyears X4 Miltek Catback @ 245BHP
          In relation to std caliper setup......Dont bother with MTEC either get EBC Black Dashes or Std OEM discs and use OEM Ferrodo pads with both setups. Spend more money replacing the brake lines with proper SS braided lines and using proper race fluid
          Job sorted and you will notice a difference ........
          Only spending just shy of 1K would you notice a real big difference ...........
            I have found some grooved EBC discs front and rear with Yellowstuff pads all round on eBay comes in at like £415 delivered.
            My question is, is it worth paying the extra for the EBC discs?
            Or are MTEC just as good? I have seen a black edition kit on eBay with the mintex pads £225 delivered. I don't really want dimpled though just grooved and I'm not fussed on the mintex pads. Maybe if I went directly through MTEC I could get some grooved discs on their own for a little less?
            I haven't looked into that yes because I got dimpled and grooved MTEC discs with Mintex pads all round on my old Corsa and whilst they were up to the job I can't say I noticed much of an improvement over the standard set up (apart from noticeably less brake dust!)
            Any advice appreciated with regards to EBC or MTEC!
              Is the car just used for road use or used on track at all?
              Standard discs, Ds2500 pads, braided lines and decent fluid should be all you need for either tbh. Worth the extra money and will put up with far more potential abuse than ebc pads and discs
              Forget about mintex stuff, cheap for a reason.
                Yeah I don't want mintex... I have two options. The EBC discs and Yellowstuff pads £415
                Or I have priced up the MTEC black edition discs with Yellowstuff pads all round would come to around £365.
                So is it worth the extra £50 to get the EBC or not do we think? I do like how the MTEC discs have the black coating and therefore won't rust.
                I do plan to do the lines and the fluid at the same time yes.
                  Call Demon Tweeks and see if we still have a group discount on EBC Black Dashes
                    +1
                    Originally posted by Bobbyp90
                    I am pretty awesome.
                    BOOM
                    the Moaning Mod
                    Clique No: 7
                      I have checked the website and they only seem to do solid discs for the Astra vxr decent price though
                        What braided lines and fluid do you recommend? I've seen there a lot of choice and want to change mine in the next month or so.
                        Tuned By Rabbid Remaps
                          Ive just had my brakes done, went for MTEC dimpled and grooved, mintex 1144 pads, braided lines all round and race fluid. Still bedding in but noticed a big difference.
                          Big Build Astra VXR Instagram - Mattyslost[/COLOR]
                            Im running the courtney braided lines but you can get HEL lines as well which are a bit cheaper I believe. I use ATE Superblue fluid (now called ATE 200) which is high boiling point dot 4 fluid.
                              HEL lines and ATE fluid is what I ran on my old one. Good stuff
