PCD and Offset
  • PCD and Offset
    Anyone know what the VXR's PCD and Offset are?
    Same as Cavalier and Calibra Turbo by any chance?
    i know the offset is 43mm but the calibras where 49
    stage 2 vxr
    [email protected]
      Reason I am asking is that I have some rather nice 330mm brakes that were for a Calibra Turbo... Just ned to know whether they will fit...
        Well considering the Thurlby 888 had 335mm disc under 18's....
        You should be okay :wink:
        The truth is out there ...
          Disk diameter isnt the issue... its whether the PCD is the same, so all the bolt holes line up...
          Also gives an indication as to whether the caliper brakets will line up...
            Yes then, all vauxhall 5 stud are 5x110
