lowering suspension with IDS+
  • lowering suspension with IDS+
    Any one know if its possible????
    John
    do you mean springs or full uprated suspension (springs & dampers)?
    yes and yes to both
      ok explain please how does that work would you lose the cdc
        Best person to speak to dude would be Thorney, he will answer any questions you have :wink:
        My VXR from Start to Finish
          if its just springs your replacing your ids+ will remain as normal, full replacement say like JohnnyVXR has done with the KW varient 3 coilovers then you no longer have the ids+ function as the dampers are replaced.
            right i'm with ya cheers mate
              if you go for the eibach kit you have to get the pro kit rather than the sprt line.
              i dont have ids so i went for the sportline. slightly lower at the front for a more aggressive look.
              the pro kit lowers it the same amount all round is is good for cars with ids :wink:
              stage 2 vxr
              [email protected]
