Spark Plugs
  • Spark Plugs
    Got myself some NGK Iridium plugs and was wondering how much of a turn people recommend once they are finger tight when fitting.
    The little picture on the box of each plug suggests 1/2 to 2/3 of a turn but, assuming the block is aluminium, this seems a little excessive?
    I'm obviously concerned about overtightening and stripping the thread in the block but notice the plugs have a crush washer so 1/2 to 2/3 of a turn would seem to make sense ...
    Any thoughts (especially from those who fit these regularly :wink: )
    Andy
    TIS says to tighten to 25Nm, not sure what that is in turns though
      I would go with the 25nm and make sure she cold.
        Yep, was thinking along these lines myself.
        Changed my own plugs for years now and a 1/4 turn was always sufficient - tightening any further than this and I would get nervous unless using a torque figure which is what I will use given the above info.
        Thanks very much guys.
        Andy
          Andy
          yep no what you mean i just change the pluge in the vectra st V6 just turned till it felt wright if you no what i mean but if you have a torque figure you may as well use it as long as you have torque wrench.
            Andy
            You've probably already changed them by now, but I normally put some copper grease (anti-seize) on the new plugs' threads just to avoid any nasty surprises trying to get them out next time :wink:
              Andy
              Great tip!
