courtenay uprated turbo actuator
  • courtenay uprated turbo actuator
    what is this for ?
    It controls the Wastegate - Opens and closes it Via Vacum. (holds the boost in or lets it out)
    My VXR from Start to Finish
      Uprated ones are stronger (stiffer) then the standard and so can hold higer boost pressures.
      If your going to be putting out high boost pressures then you might need one depending on what the standard one can hold.
        They just have an uprated spring inside... only worth doing if you are going high boost, or if your current one is weak (old- loosing boost)
        They are OK, but there are much better options out there
          You could always fit a "helper spring" which is an external fitting to your original actuator.
            where do you get these helper springs from ??
            thanks
