LED Rear lights
  • LED Rear lights
    Installed some rear led bulbs earlier. Only did the reverse and indicator lights. Didn't have enough bulbs for the brakes, 3 effin bulbs!
    Heres some pics
    It isn't as blue as that, it's just the camera. What do you think?
    Looks good, what bulbs do you need to change them all?
      I cant remember the bulb numbers, I've had them for about a year, hed them in my Corolla T Sport. Their the same numbers as normal bulbs.
      Got all the bits from ultraleds.co.uk Although I checked today and they dont sell the same ones, but there is a person on ebay that sells them, which I did use and they seem better quality Link >http://stores.ebay.co.uk/CSM-SUPPLIE...QQftidZ2QQtZkm
        and these didnt cause a fault? or the ecu didnt cut them off like on other l.e.ds??
        Astra Edition #105
          legal?
          look very very bright?
            some LEDs don't cause the fault. I have PIAA ones fitted as side lights, and had no problems.
              I had to install resistors. Simple job.
              Their not as bright as in the pics, their just a tad brighter than the originals. Their not blinding. I've had them on all of the cars, never been pulled, and went through mot fine.
                okay thanx just looked scorching in the pics
                  lol yeah I know I just like the LED flicker you get, nice and unique
                    sorry 2 sound dumb but what is piaa mate?? and if i put blue 1s of those in the sidelights will they work??
                    Astra Edition #105
                      PIAA are a Japanese bulb maker, they have just released tome terra sidelights with built in resistors that fool the ECU. They cost a bit though! If you put a normal led sidelight in it wont work, I've tried it, unless you wire in a resistor, it'll be a bit tight though
                        awesome!! wud u happen 2 know any part numbers 4 them....or have a website for them or anythin?? thanx mate
                        Astra Edition #105
                          Part nos for the terra ones?
                            yeh if they are the 1s u have in ur sidelights that dont mess up the ecu.....
                            Astra Edition #105
                              Here you go, their called PIAA Super Terra
                              http://www.hid.uk.com/acatalog/Super_LED.html
                              http://www.piaa.co.uk/bulbs/bulbshow.asp?ID=led
                              As I said, their a bit pricey, haven't brought them yet, will do though
