Question about new wheels....
  • Question about new wheels....
    This is a photoshop of the new wheels im thinking about buying.
    The problem i have is the standard wheel fitment size is
    8x18"
    These Dotz Hanzo wheels only come in 8.5x18". Has anyone fitted wheels of this size to a vxr ??
    Do they fit properly, or will they end up rubbing on the arch ?
    As these are a special order item from Germany the guy in the shop said they would probably not accept a return after they have been put onto the car.
    I think they look stunning and hope the size won't cause a problem but i would really like to know for diffinate before i buy them.
    Not sure what you are paying inc shipping from Germany but £795 from here inc. budget tyres and locking wheel nuts,
    http://dotz.alloy.wheelsgateway.co.u...=1#tyreoptions
    8.5" isn't an issue in itself but you will need the offset for starters too
      the offset is the same as the 1.2's i was looking at, so i presume that would be fine. I have been offered the wheels without tyres as my tyres are almost new for £500
        off set is off...
        I tried fitting to my Astra H and they wont go...
          hmmm, according to Dotz, it is a 35 offset, the same as the 1.2's. Did you get the correct offset wheel Dtox ??
          The wheel size im looking at states;
          8.5x18
          5x110 stud pattern
          et35 offset
          Now as the offset is the same as the 1.2's and Dap's Revolutions(i think) so the only concern i have is if the 8.5 width will cause rubbing on the arch.
            In case anyone else is interested in these wheels, they do fit and look spot on aswell.
            I will post up some pics when the rain stops and i can finally wash the car
