display
  • display
    hey folks! does anybody know wot all the hidden readings on the display mean? i know ot is oil temp n v is speed in km, the battey voltage n that but a cant work out the rest,.
    i`m just like you , i aint got a clue either,
      How do you even get them up?
        Hold down the setting button on the stereo until you hear a beep noise and then tape the 'BC' button to go through the display.
          No
          OT is coolant temp
          I thought it was oil but its not
            Hi guys, am I understandingthis correctly - the standard stereo in the Astra allows you to see the oil temp, water etc etc..? ?? if you
            "Hold down the setting button on the stereo until you hear a beep noise and then tape the 'BC' button to go through the display." quoting Jay 1983
              Not oil temp, no. It will show you the coolant temp.
                People seem to get really confused by this.....
                It does not say OT
                Depending on the display it should be read as below.
                Two seperate bits of info
                  It does not say OT
                  cool cheers but u any idea wot everything else means
