Oil and Filter
  • Oil and Filter
    Oil and filter done at 3500 miles.
    It does feel instantly quicker - is it just me?
    Had used V Power form birth - then about 5 tanks of T99, then oil change and back to V Power...
    Feels better - is it oil or petrol? (When I changed to T99 my MPG dropped and my smile widened)
    HELP
    Re: Oil and Filter
    HELP
    Its all in your head
      (crys)... [SHOUTS FOR WORSY, SHOUTS FOR FRIENDS TO HELP]
        You don't need help....it's ok....maybe it was a little of both the petrol and the oil? :wink:
          lol...its all in your head, sometimes when i put new tyres on the car i think it drives better in a sraight line
            i'm gonna change mine this weekend so will let you know if it's faster lol it's like when your a kid with new trainers i swear i could run faster and jump higher :?
              Whats the oil drain plug size and is it Torx / Socket / Hex ....... ?
                it's a torx screw just checked my new 1
                  On gran turismo on the playstation, if you changed your oil when oil was dirty, your car gained a 5% bhp boost!
                  I wonder if its the same in real life.. I very much doubt it, but if its the first oil change for the engine it should be at least running a little better.
                    Go On spoil me .......... what size is the Torx screw :wink:
                      looks like about 5 or 6 mm not much bigger
                        Many Thanks
                          Its a Torx 45 Matey :wink:
                          A little tip, when you put the socket in, give it a little tap with a hammer, then put your ratchet / Bar on and undo it - The Sump plugs are very easy to round - off!
                          My VXR from Start to Finish
                            good man still looks like about a 5 or 6 mm
                              5 or 6
                              very technical!!!!
