Wheels offset and Stud Diameter?
  • Wheels offset and Stud Diameter?
    Would it be possible to fit 5x112mm diameter wheels to a VXR? I've heard of wobbly nuts? Are these safe to use?
    Also whats the standard offset of the standard VXR wheels?
    I see dumb people.......
    .....they're everywhere
    yes you can,
    my milla miglia T12's are a 5x112 stud pattern (vag/audi fitment) which fitted with with the "wobble bolt" as there called (i machined up my own wheel bolts as i have a big brake setup so i needed a custom length).no problems.as long as you get the right hub diameter you'll be fine.
    oh and the vaux offest for the 19's is 43mm,but the vag stuff is 42mm so they are a good fit.
    ...superior horsepower through knowledge,good design and maximum efficiency
      Thanks, this might make things interesting.
