Idling
  • Idling
    Thats right was in my burg and when it is on tick over its up and down moving all over the place damm thing is annoying I thought it stays Ill post a vid up in 5 min
    http://www.youtube.com/watch?v=NYva8-jJCoQ
    Video
      Loose hose , idle control valve , cold weather , lambda sensor ??
      this is lumpy idling :-
      http://smg.photobucket.com/albums/v2...t=MOV00155.flv
      Originally posted by soosie
        mines not that bad lol
          Plug tech2 into the car an look at the RPM
          m car now idle at 950Rpm need to change that back to 750Rpm
          the truth is out there
          part GSI part VXR
            will check it
              thats what happens if you leave your type-r in the drive for 3 weeks without starting it
              took over 200 miles of varied driving to cure it , its very common on type-r's
                is it
                I might try.. but I use mine everyyyyyyday
                  also it will jump around a bit on tech2 it will not sit at 750 it will jump up an down at Bit its a engine not a computer
                  goes from 748 to 788rpm up an down all the time
                  part GSI part VXR
                    but not like mine atm up down up down
                      Mines exactly the same, sounds like it's missing, but I've been on a Rolling-road recently and mine is running just fine.
                      Might be something to do with the remus, but deffo nothing to worry about.
                        its the in line 4 engine Dont worry about it
                        part GSI part VXR
                          tonight its weird I had it months and no problem or is it just something I noticed tonight
                            http://uk.youtube.com/watch?v=dCXzb2Tr79E
                              Mines a standard Vxr (not a burg) and my revs fluctuate just like the burg in the first video, both when the engines cold and warm. Vxl said nothing to worry about.
