Brake Fluid for Big Brake Kit's.
  • Brake Fluid for Big Brake Kit's.
    As above, what do you use been recomended these:
    http://www.opieoils.co.uk/p-740-cast...ake-fluid.aspx
    http://www.opieoils.co.uk/p-894-motu...h-systems.aspx
    What do you use?
    I see dumb people.......
    .....they're everywhere
    Ate super Blue
    its a racing 4 DOT
    I get that from euro car parts
    £12 for 1L
    the truth is out there
    part GSI part VXR
      Ap Dot 5.1
      My VXR from Start to Finish
        http://images.google.com/imgres?imgu...en-US%26sa%3DN
        I use this an find this Fine for Road use and track use
        have a look at
        http://www.eurocarparts.com/
        part GSI part VXR
          I also use AP Dot 5.1
          sigpic BURG 472 Gone
            me as well
            GONE BUT NOT FORGOTTEN!
              Thanks guys, ordered some AP 5.1
                standard Dot 4 for me, 5.1 is ok if you are on the track and changing it every few months. But for my road car I am happy to use the normal road spec fluid and change it every 2 years
                  Can you expand on that anymore? And by standard dot 4 do you mean whats used by vauxhall?
                    dot 4 esp
                      Originally posted by vxr bad boy View Post
                      dot 4 esp
                      Yeah, take it that the standard vauxhall stuff. But surely Ap 5.1 doesn't need changing every few months?
                        the higher the dot number the more frequent the fluid needs changing due to the fact that is has a higher hydoscopy (not sure if I just made that word up!!!). So the higher the number the more water the fluid can retain. When brake fluid is heated it still does it's job well. When brake fluid + water is heated the water boils and turns to steam but condenses straight back to water when it cools. When it is steam you get compression in the brake lines (spongy pedal). Therefore you need to change it more often. Read the packet it comes in. Also always buy brake fluid in a metal can not a plastic one. Plastic bottles often have no seal under the cap so are absorbing water from the atmosphere from the day there are made. Metal cans (namely Castrol and other big brands) are put in metal cans with a rubber seal on the cap to stop any air being allowed to come in contact with the fluid until the seal is opened
                        I hope that clears it up
                          you would be better off keeping your brake fluid standard and changing the brake lines to the braided type,there's no need to upgrade brake fluid for road use
                          See No Evo, Hear No Evo, Fear No Evo! 508bhp,540lb/ft
                            B*ggered with your DOT 4 from Vauxhall in its Plastic bottles then eh
                              How often do you change you brake fluid Daz? I've just bought some 5.1 but don't really want to change it every few months.
