Not good considering it's the leading VXR site!
  • Not good considering it's the leading VXR site!
    I've been trying to get the wheels off my Burg to give them a coat of Colly for the winter.
    So I thought I'd check here to see if I could get advice for JACKING points.
    NIGHTMARE!!!!
    There's no proper advise to do this I managed to guess my rears from a picture someone posted but the fronts!!....I have NO clue and gave up.
    Can someone with some proper experience make a guide on where its safe to jack our Astra VXR using a trolley jack.
    And then could a moderator please make it a sticky in the how to section.
    To many people have different opinion's about this but only the people who KNOW what there talking about should be giving the advise.
    Thanks..
    why don't you give vauxhall a ring? if you want to make sure your given the right way of doing it?
      I think for me and other novices like me we need visual guide. Plus from what i read half the VXL garages don't know either due to the numerous damaged side skirts peeps complain about on here.
        ture
          You might find that you get more replies if you asked the question, instead of slagging the site off !! Some might say if you can`t jack it up you shouldn`t be allowed to take the wheels off *lol*
            true possibly. your right this is basic stuff thats why i thought it wuld have been covered on here properly before.
              If you look under the site skirt, you will see the sill running along the underside, there is a little 'V' sort of shape cut - out which are the official jacking points, however i prefer to go somewhere a bit more structural.
              In all fairness, if you are having doubts and arent sure where to jack the car up, should you be tackling such a job ?
              My VXR from Start to Finish
                Don't jack directly onto the jacking points in the sill with a trolley jack. I usually use a piece of soft wood in between to protect the car, so as i don't end up with a bent up mess at the end.
                  this has been covered before on here. Andy put a post up of where to jack etc, after someone on here got there sideskirts split after it being jacked in the wrong place.
                  Burg blood in my veins.... Ice cool Baby!
                  !!Warning a VXR may inspire confidence!! Now for sale
                  http://www.vxronline.co.uk/forum/sho...ds-and-stanced!
                    I jacked mine at the weekend and found the posts confusing and got quite in a muddle, but then I went out got the trolley jack out and a piece of wood and jacked it up where the indent is on the sill. Had the wood running parallel under the sill to spread the load.
                    Remus 3 Piece - Bilstein B12 kit - Nurb Splitter - OPC Fogs - Debadged
                      so using a piece of wood and trolley jack you jacked it up where the groves are for a normal jack,
                        nightmare??? how???
                        search
                        http://www.vxronline.co.uk/forum/sho...jacking&page=4
                        http://www.vxronline.co.uk/forum/sho...highlight=jack
                        GONE BUT NOT FORGOTTEN!
                          just what the man Said
                          the truth is out there
                          part GSI part VXR
                            yup daz, worked a treat.
                              Because its unclear. the picture shown is for the rear. I have read these posts and ended up confused and $hit scared to jack it.
